Rear end ring and pinion compatability?
Old Oct 29, 2008 | 07:24 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Hey just doing a double check to make sure I can do this.
Is a 91 10 bolt with 3.42 gears compatible with any 89 and up 28 spline 7.5" gear 3.23 and up?? Are they both 3 series carriers?
I found an axle and he wants to keep the gears and I want to go to a 3.23 gear anyways, but want to make sure I don't need to switch carriers.
Old Oct 29, 2008 | 08:05 AM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Re: Rear end ring and pinion compatability?
Should not be any problem switching the gears if I remember correctly, just remember 28 spline axles will not fit into the 26 spline carrier. The 28 splines are just big enough they will not fit through the bearings.
Old Oct 29, 2008 | 08:54 AM
Car: 92 Z28
Thanks, I know the 26 splines wont jive. I just couldn't remember which carrier the 3.23's had, I know the series 2 carrier requires an extra spacer to work with higher gears though. Was not sure how the opposite would work though (series 3 carrier with a lower gear).
So the cut off for the two series carrier is a 3.08?
And ANY 3.23 and up gear set for a 28 spline 7.5 ring gear will work with the series 3 (ie fourthgen gears?)
Old Oct 29, 2008 | 08:56 AM
big gear head's Avatar
Yes, 3.23 fits the 3 series.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
