stall selection
Old Feb 19, 2001 | 01:22 AM
burnoutrpm's Avatar
stall selection
i was thinking of using the matching cam for the performer rpm intake and was wondering if a 2,100 rpm stall is enough??? what about low end using a stall? will it still be there??? the cams specs are:
.488/.510 lift 234/244@50 duration. 112 lsa.
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 19, 2001 | 10:42 AM
The ODB's Avatar
that camshaft is complete junk.
2100 is not enough.
A good converter like the Vigilante will increase your bottom end.
Old Feb 23, 2001 | 08:29 PM
sleeper's Avatar
A 2100 converter is too small for the camshaft. You should be making maximum power around 2500-2800rpm. I'd say a 2600rpm converter with a 3.23 or 3.42 gear would work best here and still get decent mileage. Your cylinder heads are weak and are the worst part in your system, spend $850 and get the Trick Flow heads from Summit. With them you will be getting mid 13 second times.
Old Feb 24, 2001 | 07:27 AM
Biochem's Avatar
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by The ODB:
2100 is not enough.
</font>
I couldn't agree more! That cam is one of the worst for street use. You will have a crappy idle and no porwer until about 2500 rpms. With that said, you will need a converter in the 2800-3000 rpms stall range to make the best use of that cam and some good heads to make that combo live like it wants to at the upper rpm range.
I like my Comp Cam 262 grind and I have to pass the emissions check from hell in this state. I may have gone with a larger LSA (112-114) to calm my idle a bit, but it is certinly torrlerable when the car warms up. I have a ~3000 stall converter too.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
