Best value/performance torque converter...
Old Feb 21, 2001 | 06:22 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
I have a transmission from The Tranny Doctor and I am in search of a converter. The range needed is around 2800rpm. It will be daily driven and see some occasional strip use. The motor is a small block 400 producing over 400hp. I have looked at Vigilante, and Yank since I have heard they were the best. I guess I am going to have to get used to the fact that 700-800 for a converter is the norm. Just seeing if this is true I will have some saving to do in that case. Thanks
91 Firebird 305/TBI - cam:.420/.442 204/214 - Hooker 1 5/8" headers - TFX PaceSetter Cat-Back - 3.42's Auburn Pro Posi - ASCD Ram-Air hood - Polished Formula Wheels w/Futura's - Open element - .5" Corian TB spacer - Lakewood LCA's - Hotchkis Lowering Springs - KYB Struts/Shocks - 14.78 @ 97.5 mph(G-Tech) - MacEwen MotorSports Whiteface Overlays - 412ci sb waiting to go in this spring.
My Homepage
Old Feb 23, 2001 | 11:19 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
So which is it the 9.5" Vigilante 2800 ?
Old Feb 24, 2001 | 10:50 AM
88 IROC BOB's Avatar
That's exactly what I bought but I haven't put it in yet. This is what PI recommended for my car and I still have stock heads and cam.
They assured me this stall will work great in my car.
I'm also going to get a trans cooler too.
Everyone who has a Vig has seemed to be very happy with it, I don't think you'll be disappointed either!
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Feb 24, 2001 | 11:34 AM
kwikgta's Avatar
Try http//www.racingtransmissions.com/prices.htm
they have a 10" lockup for $575,stall cane set anywhere from 2500 to 3500.Several people here have used them in the past with no complaints.I will be plcing my order next week!!!
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
Old Feb 24, 2001 | 11:39 AM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Kwikgta I tried the site but it was under construction.
Old Feb 24, 2001 | 02:50 PM
kwikgta's Avatar
Whoops,put a hyphen between "racing" and "transmission".Sorry dude.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
