bought a used t-5:need specs for t -5 synchros
Old Feb 25, 2001 | 07:49 PM
mikeage2's Avatar
well i bought a t-5 out of a 87 iroc.i took off the tailhousing and cover.everything inside looks ok.i know theres supposed to be XXXXX ammount or space in between the syncro and the hub it presses against,measured with feeler gauges in thousandths i think.what is the spec for that?its not in my book.i dont want to re-build this if i dont have to ,it loosk ok,but i just want to make sure the synchros are ok before i bolt this trans up and have to rip it right back out
mike
86 camaro:was a v6 car with stick,converting to v-8..NEED A V-8 T-5!!!!!!!!!!email me if you have one!!!
350 cylinders bored .040 over.a little oves 9:1 compression(getting a blower some day when im rich lol)line bored.deck milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194 intake valves,pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(wel at least they look nice lol)and intrepids all day makes me drink too much
good job security though
Old Feb 25, 2001 | 08:15 PM
merf23's Avatar
The non WC synchros are quite durable. Sorry i dont have a spec on them, but I look at the teeth on the outside and the grooves on the inside...all should be sharp. Also, while you have it apart, check the side clearance on the countershaft and the preload on the mainshaft. If you'd like i can send you a word file that RB wrote to me a coupla years back about rebuilding a T-5.
merf23@yahoo.com
Old Feb 25, 2001 | 08:36 PM
mikeage2's Avatar
its not all the way apart,so i cant look at the grooves on the inside of the synchros...they all look sharp+clean
i just want to make sure that theres enough wear material left on the synchros.if that spec is out,then ill totally dissassenble and replace them
86 camaro:was a v6 car,now its going to be a v-8 5.7l!!
350:cylinders bored .040 over.a little over 9:1 compression(getting a blower some day when im rich lol)line bored.deck is milled a little(was pitted)
194? intake valves(not 2.02( ),pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
working on freakin NEONS ,cirruses,tauruses,cobras(well` at least they look nice lol)and intrepids all day makes me drink too much
im always on the lookout for cheapv-8 t-5,s
and t-56 setups.they must be cheap.i dont care of they need rebuild,as long as they arent totally blown
92GTA
Apr 9, 2016 07:39 AM
86IROC112
Sep 7, 2015 01:37 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
