How do you tell what year a disc rear is?
Old Feb 25, 2001 | 12:26 AM
86IROC305's Avatar
I found a disc brake rear at a local salvage and need to determine what year it is. The confusion is that the car is a 84 HO Z28(verified the vin#), which I know had disc rears avalible. The gear ratio is 3.45, which was NOT avalible until 87 and the car has a 145mph speedo also(some swapping definatly done). How can I tell if it's the problematic pre 87 or upgraded post 88 disc rear?
86 TPI 305 Iroc-Z
700R4 (rebuilt)
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams H268 218@.050 454/454 110 LSA
Old Feb 25, 2001 | 08:58 PM
Nordbert's Avatar
The later rearend should have a 9 bolt cover.
The axle code is stamped on the front and
center of the right axle tube. The salvage
yard should be able to decode it for you.
If not, someone on this board probably can.
Old Feb 25, 2001 | 10:02 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
also after 89 the disc calipers were made of alluminum, and both installe on the back of the rotor. On 88 and earlier they were, back drivers side/ front pass side. Again the 87 up were 9 bolt
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
