Another 700 Question
Old Nov 2, 2008 | 07:49 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I just had my 700 rebuilt. It has a stage 2 b&m shift kit. The thing just doesnt act right. IF you put it in Drive and just take off it just bam bam bam bam and your in 4th gear by 40 mph and smash it to the floor and all it does is drop to 3rd. We have set the cable with no luck. It also slips just a little going into 3rd
http://www.youtube.com/watch?v=KlOQE_YJ1Wg
listen as it goes into 3rd.
is there somthing im missing??
If we tighten the cable any more than it is it will not shift out of first gear.
Old Nov 3, 2008 | 06:27 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: Another 700 Question
Sounds like it has a third gear flare. 3-4 clutches may be going, or maybe a line pressure problem (not enough). Did it work fine before the shift kit install?
Old Nov 5, 2008 | 10:51 PM
Brando5641's Avatar
when it was built it had the kit installed. i just bought a corvett survo. Do you think this will help it grab 3rd better?
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
