Good synthetic for t56 ?
Old Feb 25, 2001 | 12:38 AM
AustinT's Avatar
What is a good synthetic Oil for my t56? How Much do I need to get? Does the t56 use the ATF like my old t5 did?
Old Feb 25, 2001 | 09:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Whether it uses ATF, gear lube or motor oil, get AMSOIL. I got started with the stuff in '83 when my T-50 (yes, 5-speed behind a '77 Buick V6) kept missing the 1-2 shift. After the AMSOIL ATF, I never missed that shift again.
If gear lube, get the Series 2000 75W90. Great stuff.
Not sure on the capacity, but 2 quarts has taken care of any car manual tranny I've seen.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Feb 25, 2001 | 02:27 PM
AustinT's Avatar
Amsoil it will be!
I think it uses atf Can anybody confirm this? Any body else know capacity?
Old Feb 25, 2001 | 03:37 PM
five7kid's Avatar
I'll show a little ignorance here. The book I have says "Corvette 6-speed, '97-up, 8 pts". "Corvette, '89-96, 4.4 pts". "Camaro 6-speed, '93-'97, 8.1 pts". Only goes to '97 models, hope yours is covered by one of those (not sure exactly which was a T-56). Guess it's been too long since I've seen manual trannies.
The '89-'96 Vette says gear lube, all the others say ATF.
Old Feb 25, 2001 | 04:11 PM
theformula's Avatar
I have heard nothing but horror stories from 4th gen owners using synthetic fluid in their T-56's. Use what the manual says
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 25, 2001 | 04:25 PM
ede's Avatar
ede
i use mobil 1. if 5.7 kid starts giving me free samples of amsoil then i'll send every one his way
ICON Motorsports
1st & 3rd
Old Feb 25, 2001 | 08:23 PM
AustinT's Avatar
What kind of Horror stories. I thought synthetic would make it shift smoother?
Old Feb 25, 2001 | 11:42 PM
five7kid's Avatar
<font face="Verdana, Arial" size="2">Originally posted by theformula:
</font>
I've never heard of any such thing. Are they trying to use gear lube instead of ATF, or something like that?
A couple of points:
1) The manual will give a type and spec. If the lube you are using is of the right type and meets the spec, you can use it.
2) If a manufacturer says you can only use their product, they are required by law to provide it free of charge.
I'd be interested to know exactly what these "horror stories" are.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
APDYNO
Aug 8, 2015 04:11 PM
