Manual trans. choices for BBC (502) swap?
Old Feb 25, 2001 | 05:53 AM
G92Joe's Avatar
I'm planning to swap a 502 into my '87 GTA. Im not sure if a T56 6-speed will handle the toq/HP. Does anyone know the output ratings for this trans? Anyway to increase it's durability/strength? (I want to use this trans. because of the 0.5 O.D. in 6th).
Old Feb 26, 2001 | 04:43 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am moving this to the transmission board.
Old Feb 26, 2001 | 10:33 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
How much horsepower/torque are you planning on making? I've heard of LT1 F-Bodies pushing 500 hp that are still using the stock T56. If you want to though, you could get a ZF6 transmission from an '89-'96 Vette. These are a little tougher than the T56 but are more expensive and harder to find. Right now, GM is putting them behind their 6.6 liter turbo diesel V8 that produces 520 lb. ft. of torque and 300 hp. It is also used behind the new 8.1 liter big block V8 that makes 340 hp and 455 lb. ft. of torque. Both of these are in the new HD Silverado. I don't think there are any major internal changes to the transmisiion from the Vette to the truck. Just a different case.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Feb 27, 2001 | 04:38 PM
JeffT's Avatar
Car: 1991 Z28
Richmond 6 spd and forget about it!
Hello, Michael
Aug 20, 2015 03:19 PM
sreZ28
Aug 14, 2015 07:48 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
