BW 9-bolt gears
Old Feb 27, 2001 | 04:14 PM
Steve R's Avatar
BW 9-bolt gears
What are all the aftermarket or GM gears available for the Borg-Warner 9-bolt?
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Feb 27, 2001 | 04:44 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
GM 9-bolts came with 2.77, 3.27, 3.45, and I've heard 3.70 but I've never seen one.
Aftermarket companies only sell 3.70, and they will only fit cars that came with 3.27 and 3.45, they will not fit 2.77.
www.ring-pinion.com
www.drivetrainspecialties.com
www.calgear.com
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 27, 2001 | 06:54 PM
IROCeastTN's Avatar
So whats a guy, who happens to have a 2.77 BW, to do if I want lower gears?
Old Feb 27, 2001 | 08:33 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I feel for ya man, I have the 2.77 gears in mine too!! You can actually get gears that WILL fit but you have to get them from GM directly and they are VERY expensive! Call and check it out sometime!! The only other option you have, which is the one I will probably go with, is to find a 10 bolt rear out of another thirdgen and swap it in!! But if you're like me, you have the rear disc brakes and finding a 10-bolt rear with disc brakes is going to be difficult task!!
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
Actually in 1985 the borg warner 9 bolt rear ends came with 3.08, 3.27, 3.42, 3.45, 3.70, 3.73, and 3.75 gears!
In 1986 the 2.77's were introduced and the 3.08, 3.42, 3.73, and 3.75 gears were eliminated from the borg warner rears leaving just the 2.77, 3.27, 3.45, and 3.70 rears!!
[This message has been edited by 86TpiTransAm (edited February 27, 2001).]
[This message has been edited by 86TpiTransAm (edited February 28, 2001).]
Old Feb 28, 2001 | 12:08 PM
89ProchargedROC's Avatar
actually kevin forgot to mention that GM also produced 3.08 gears for the 9 bolt. if some of you have 2.77 gears.....we have some used posis that are in good conditions laying around my shop i could sell you. then you get your 3 series gear
Old Feb 28, 2001 | 07:15 PM
Kevin91Z's Avatar
I dont mention the 85 ratios because they are so rare. Most people have the 86-89 versions, which have the ratios I stated.
Old Mar 1, 2001 | 04:52 AM
ausrs's Avatar
actually they also make a 4.11 ratio for the 9 bolt
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
