New Product! Transmission Swap Crossmember w/ Trq. Arm Mounts
Old Nov 7, 2008 | 11:29 AM
UMI Performance's Avatar
Hello Members,
UMI Performance is now offering torque arm relocation kits for the 82-92 F-Body. These kits work with factory length torque arms and mounts them off the tail shafts. They work excellent when swapping transmission such as a TH350 or TH400 in your 82-92.
If you have any questions please ask. Thank you!
Ryan
700R4 & T5- www.umiperformance.com/2228
TH350- www.umiperformance.com/2230
TH400- www.umiperformance.com/2232
Old Nov 7, 2008 | 12:44 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: New Product! Transmission Swap Crossmember w/ Trq. Arm Mounts
Cool. Now you just need to make one for the T56.
Old Nov 7, 2008 | 01:36 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Old Nov 8, 2008 | 09:07 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
yes, one for t-56 in a thirdgen is a must!!!
Old Nov 8, 2008 | 11:01 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
and might as well also do it to take TH400, 4L80E, and my favorite, the 200-4R
Last edited by Atilla the Fun; Nov 8, 2008 at 11:02 AM. Reason: Automerged Doublepost
Old Nov 9, 2008 | 08:29 PM
vbMike's Avatar
Not sure about other trannys but on my T56 I have a poly mount and it has three bolt holes to attach it to the crossmember. I'm not sure if all tranny mounts are like this or if it's just the poly mounts but it would be nice if the bracket on the crossmember would accomidate the three bolt tranny mount.
An optional drive shaft loop would be nice also.
Old Nov 9, 2008 | 09:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
and if you can fit 3 bolt heads side by side by side in the mount....
most aftermarket crossmembers, have 3 slots, you can use 1 or 2 bolts. Not 3.
Old Nov 9, 2008 | 10:03 PM
vbMike's Avatar
I got 3 bolts in mine. It was a tight fit but I got them in there.
Old Sep 6, 2012 | 07:44 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Wrong thread my bad
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
