What flywheel/starter do I need?
Old Nov 6, 2008 | 05:37 PM
vodkya's Avatar
Re: T5 FAQ - Everything we know about the T5
I have an 88 camaro sport 305 tbi 5 speed. I am swaping the engine out for a 69 350 and need to know what flywheel/starter combo I need. The factory flywheel has the small center hole which will not fit my crankshaft. Any help at all????
Thanks.
Old Nov 6, 2008 | 07:12 PM
Hubes's Avatar
Car: 85 Z28
the 69 block has a 2 piece rear main seal, the 88 has the newer 1 piece rear main seal that they started using in 86. the cranks are different so youll need a flywheel to fit the older style
Old Nov 12, 2008 | 04:41 PM
howesbird's Avatar
Car: 1988 Pontiac Firebird
Engine: Pontiac 400
Transmission: 4L80e
Re: What flywheel/starter do I need?
try an 83-85 friebird/camaro then try any big truck before 86
the goal is to get the right number of teeth on the flywheel to my knowledge
gm only made to a small and large. In turn they made two starters the straight bolt pattern and staggered. The staggered one is for small flexplate/flywheel and the straight is for the big flexplate/flywheel
gimme a email at
howesbird@yahoo.com if you have any questions
