When swapping rears....
I was just wondering a couple of things.. First if swapping out a non posi rear for a posi rear does it matter if the "new" rear that you are putting in was on a manual or automatic car? I am looking for an easy swap.. also how can i tell if i have a posi or non posi rear? I have an 87 Camaro IROC w/ disc brakes all the way around as of right now..
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: When swapping rears....
The RPO's G80 will provide an idea, but you'll never really know until you pop the diff cover and take a peek.
JamesC
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
does it burn out with both wheels or just one?
If it burns with both wheels it is a posi or a limited slip.
It doesnt matter if it is automatic or manual !
The wheel/burnout test can be misleading. Pull the cover. Check the pic in the following link:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
JamesC
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
turn the wheels of the car, if its at a junkyard. if both wheels spin the same way when turned, its a positraction, if one spins one way and one the other, then its an open diff. on newer camaros which i believe are 99? and up, have a zexel torsen diff. which will appear to be an open diff. but really are positraction units
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Id look for manual cars first, most of them had like 3.42 gear ratios. Also the best way is to pop the diff cover and see if there is a posi unit in there. But of course the easiest would be to just spin the wheels.
Hello, Michael
Aug 20, 2015 03:19 PM
