98_1LE
close
- Join DateMay 2000
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Liked:18 Times in 14 Posts
How are the shift points changed in a 700R4. I'm planning an induction swap on my Formula and will need to raise the shift points from the stock 4600 rpm.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
You can get a kit to change the governor springs.
Just manually shift it! Then it doesn't matter what the shift points are!
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 355 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Intake, Hedman Shorty Headers, Stock casting pocket ported heads (2.02/1.60 - 65cc), XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
