rear gears.....
Old Mar 7, 2001 | 08:59 PM
toosloz's Avatar
rear gears.....
sunday i snapped an axle on my limited slip rear......it has 3.73 gears.....i have replaced it with a rear with a 3.27 posi rear....can i reuse them gears in this rear....its a same year run rear end
84z28HO
305 or 350?......
m5/373s
performer intake
performer 600cfm carb
accel blue print series distributer
super hei
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gto blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
Old Mar 7, 2001 | 09:07 PM
Birmass's Avatar
As long as the 3.27's were the original gears in the carrier(as long as it's a 3-series carrier in other words) and they are both ten bolts, then yes you can.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
Old Mar 7, 2001 | 09:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
3.27 = 9 bolt.
Won't work.
Unless someone told you wrong. Count the cover bolts: 9 = 9 bolt, and probably 3.27.
10 = 10 bolt, and probably 3.23. Then, yes, your 3.73 gears will fit.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Mar 7, 2001 | 09:55 PM
Birmass's Avatar
Thanks. I couldn't remeber whether the 3.27 was the 9 bolt or if the 3.23 was.
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
