Stock Shifter with TH350?
Old Nov 13, 2008 | 08:25 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
Axle/Gears: 2.73 open
I have a shift kit and i'm wanting to manually shift with the stock shifter until I can get a ratchet shifter. The problem is that the stock shifter won't engage 2nd or 1st. The last detent that I come to is Drive. Any quick fix for this or am I out of luck until I can get an aftermarket unit?
Old Nov 15, 2008 | 04:34 PM
jmonkey91's Avatar
Re: Stock Shifter with TH350?
Yes if you unhook the shift linkage from the trans and put the trans in park then put the shifter in park position, than hook it up you should be ok for now
Old Nov 15, 2008 | 09:48 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
How would this change anything? Park is lined up...
Old Nov 17, 2008 | 09:49 PM
jmonkey91's Avatar
well i have had a third gen with the same trans in it and this is how i had it if your not getting all of your gears than some else is wrong !!
Old Nov 17, 2008 | 09:53 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
I'll see what I can do. The gears are there, I just can't select them.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
Genopsyde
Oct 7, 2015 08:35 PM
NBrehm
Aug 25, 2015 11:49 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
