t5 from 2.8 fit small block?
Old Mar 11, 2001 | 12:38 PM
patgizz's Avatar
will a t5 from a 88 2.8 car fit a 89 iroc small block car(with the exception of the bellhousing of course)?
Old Mar 12, 2001 | 04:12 PM
Fastcamaro87's Avatar
yes it can, however the v6 clutch disc is smaller, and the v6 tranny is geared differently.i wouldnt reccomend it but it can be done.
and i also beleive the output shaft has a different spline count in which case u would need a driveshaft from a v6 car.if anyone knows for sure pleas post, this info.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Mar 12, 2001 | 05:54 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its the input shaft that is different, the output shaft is the same. I would not recommend doing this at all, but it is possible.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
