Ford 9" install......
Old Mar 12, 2001 | 05:07 PM
Hi-psi's Avatar
Guys,
Getting ready to put a 9" in the TTA next week. I was wondering if anyone had any instructions or pics of how to install. Actually putting the rear in the car is pretty straight foward,...I'm more worried about putting the center section into the housing and bolting the axles in. Also,..what type of gear lube should I run, and how much of it? Thanx.
Robert
'89 Turbo Trans Am
#799 of 1555
11.96 @ 109.11 w/1.62 60ft BEST Race Gas
12.53 @ 105.31 w/1.74 60ft.BEST Pump Gas
www.Hi-psi.com
Old Mar 12, 2001 | 06:32 PM
ede's Avatar
ede
since you didn't say i'll ask, is it a rear made for a third gen? ok with that out of the way to put the carrier in just put it on the studs, with the gasket and tighten the nuts. i'd use mobil 1 and friction modifier, if required. the axles push in from the brake side (big suprise) and bolt up at the backing plates. putting the rear in the car isn't very hard or much work at all.
ICON Motorsports
1st & 3rd
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
mcbitchman
Sep 29, 2015 12:32 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
