D to OD at wot
Old Nov 18, 2008 | 03:05 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
D to OD at wot
how do i make it shift from d to overdrive at wot..what aftermarket parts does the trick
Old Nov 18, 2008 | 03:59 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: D to OD at wot
i think the vette servo will allow this, but im not sure, i had it done to mine when it was built, but i dont know what the guy did to it to make it do the WOT shift
Old Nov 19, 2008 | 11:07 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: D to OD at wot
it's a valve in the valve body, not the servo. B&M was the first to offer this, you can find the kit at www.summitracing.com for like $35 or so.
Old Nov 19, 2008 | 11:23 AM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
Re: D to OD at wot
thx atilla
Old Nov 20, 2008 | 05:09 PM
89RS_82Z's Avatar
Re: D to OD at wot
that jack *** the built my trans better have done it right............ill find out as soon as i get it in and broke in
Old Nov 20, 2008 | 08:27 PM
performabuilt's Avatar
Re: D to OD at wot
Generally that valve is a option not something automatically used in a build for the reason some people do not like it due to part throttle kick down issues
Old Nov 20, 2008 | 09:11 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: D to OD at wot
i thought that part just delays the kickdown untill 2/3rds throttle? not sure but i think the OP is asking for full throttle shifts
Old Nov 21, 2008 | 09:52 AM
Shagwell's Avatar
Car: projects.......
Re: D to OD at wot
I really don't reccomend those valves unless you have a billet OD servo along with a really good 3-4 clutch pack and properly performing valvebody and pump. Even then, much over a few hundred hp you're asking for problems. - OD was not designed for performance/WOT operation.
Old Nov 21, 2008 | 10:11 AM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
Re: D to OD at wot
i herd some shifts kits do it to?
Old Nov 21, 2008 | 10:51 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: D to OD at wot
This kit is based on what Chevy put in the 'vettes. Those 'vettes do kick down at like 3/4 throttle, but do give WOT upshift.
Old Nov 21, 2008 | 04:24 PM
89RS_82Z's Avatar
Re: D to OD at wot
well mine is built to hold some power...all top end racing parts in it
and i was told that i will have the 3 to 4 @ WOT....... granted it aint going to get up to that much if any, just nice to know its there
Old Nov 23, 2008 | 02:16 PM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
Re: D to OD at wot
my trans has a habit of staying in overdrive till about 1100 rpm on the hills unless i tap the gas pedal is that normal?
junior419
Apr 7, 2025 11:35 AM
Pac J
May 17, 2020 10:44 AM
86White_T/A305
Mar 6, 2016 01:48 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
