Swap Question!
Old Nov 18, 2008 | 06:48 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Swap Question!
Will a '92 Camaro 700R4 work in a '88 Trans Am? I know they are the same tranny but I was wondering if the years apart made a difference? The Tranny is coming from a 305 to a mild 355.
How long does a tranny swap take? How complicated also? Seems pretty straight forward.
Old Nov 19, 2008 | 11:00 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Swap Question!
It'll be a direct bolt-in. If this is your first time, and you're doing it in a driveway with jackstands and a floor jack, expect it to take a full Saturday. In good weather. Longer if it's cold and miserable.
This is the time to do the poly trans mount upgrade, and if you want, any other upgrades, such as a corvette servo, or shift kit, or looser torque converter. If you have an aftermarket converter you like, be sure to get it flushed so any debris in it doesn't ruin the '92 trans.
Old Nov 19, 2008 | 10:02 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Swap Question!
Are things like the servo and shift kit direct bolt-in kind of parts? Could someone with little to no tranny experience put them in?
Old Nov 20, 2008 | 10:23 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Swap Question!
The corvette servo is usually easy, depending on where you get it. If you go to a local transmission rebuilder, you won't get any instructions with it. You need the instructions. This upgrade increases the holding ability of the band, which applies in second and overdrive. If your 350 is making serious power, this isn't a bad mod to do.
Shift kits are more controversial. You'll hafta read up on them and decide for yourself, but I feel it's worthwhile, and easier with the trans not in a car. Just keep in mind that most brands have instructions written for installation with the trans in the car. My own preference is www.tciauto.com
In any case, the poly trans mount is easy, and cheap insurance.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
