700R4 Crossmember in '82 TA
Car: 1982 Pontiac Trans Am
Engine: SBC 355
Guys, I need some help. I've swapped an 87 350 TPI/700R4 combo into a 1982 Trans Am. However, the crossmember from either year will NOT line up with the tranny mount and the holes in the frame. I've been looking everywhere to find someone who offers this crossmember, but to no avail. Has anyone else out there done this swap and had a crossmember made? If so, could you please give me dimensions or pictures? I've even tried making my own but when I go to line it up on the car, it still doesn't work. I suppose this is the one thing that would have to hinder me since it's the only year with only the TH200 available. Any help from you guys is very appreciated. Thanks.
- Bob
- Bob
I ran into this same problem swapping a t-5 into my 82 trans am. Rather then modifiy the frame of the car, I modified the stock 82 crossmember. I welded on a 1/4" steel plate to the top of the cross member, overhanging on the necessary side(forget if it was front or back" I then installed the crossmember, dropped the tranny down so it touched and made a little mark in the new plate, then removed the crossmember and drilled the hole.
It turned out that I needed to notch the side of the crossmember because the bolt would have come down right in the middle of the side. Anyway, it worked out great, and I didnt cut have to cur holes in my frame. If you fu*k up a crossmember, its alot easier to replace than a frame.
I dont have any dimensions, basically I welded on a plate that was plenty big, and drilled the hole where necessary.
Good Luck.
Good Luck.
Transmission: 4L80E/4L80E
Do like ODB says and drill holes in the frame to match the '87/TH700 crossmember. I did exactly that thing, had to punch another hole towards the end of the frame section to slide a nut/washer in there for the stock-type bolt.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
In my 82 bird, I went from the 2.8l v/6 and a 4speed to a 350 with a 700, I used the same 4spd crossmember front holes of the crossmember bolted right up to holes already in the body. Only the rear holes of the crossmember did I have to drill and use spacers on (which I did long after the fact).
Mike Metzler (Desert86Roc)
Mike@SpeedworldMotorplex.com
[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For My Racing Page[*]86 IROC 305 TPI (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, Headers, no NOS)
Thanks, Mike, that's what I should have said... Except that I had all 4 bolts before the tires hit the pavement!
We can build you a crossmember that will bolt right in using the existing mounting locations on your 82 car.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Steve
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
