Converter lock up question
Old Nov 20, 2008 | 06:35 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
My car has been shifting into OD at 40 mph and locking the converter as well. The tranny only has about 2000 miles on it and its a probuilt kit, along with a vigilante converter with less than 500 miles on it. When it shifts and locks up its very harsh and makes the car jolt until I get to around 47 mph. I have just been manually shifting for now. What could be the problem?
Old Nov 20, 2008 | 08:21 PM
performabuilt's Avatar
Re: Converter lock up question
with the gears you have you probably need a lighter weight converter such as comes in taxis and police car this will raise the shift point and make for a much better feel .
Old Nov 21, 2008 | 10:12 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Went I had my 2500 converter in there it worked just fine, its when I sent it in to get restalled it started to do this. I was wondering if there is anyway to program the converter to lock up at a higher speed?
Old Nov 21, 2008 | 10:46 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I suspect performabuilt meant governor rather than converter
Old Nov 21, 2008 | 05:47 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
IIRC J.E.T made a TCC delay module that delays lockup till 4th gear.
Old Nov 21, 2008 | 06:42 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It needs to be reprogramed in the chip to a higher MPH.
Shift points of the trans are taken care of by the governer.
Old Nov 22, 2008 | 01:40 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i agree.
you can take out your own governor and just take off some of the weights with a drill or grinder if your careful
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
