700R4 rebuild
Old Mar 12, 2001 | 11:33 AM
Skip Howard
Guest
Posts: n/a
700R4 rebuild
I'm sure one day it will be time to rebuild my trannie. Is it worth trying to do it myself or is it something left for the pros? It's an area I've never touched except for filter changing.
85T/A 305/QJ work in progress.
Old Mar 12, 2001 | 05:30 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I just started one two weeks ago (in spare time)
Don't deadline yourself on building it or you will forget one of the million rubber o-rings somewhere. I disassembled the whole thing with 4 sockets&3/8 ratchet, a hammer,a pair of needle nose, two flathead screwdrivers...
The hardest part was getting the low/reverse piston spring assm out of the case because you need a special tool ($63 ridiculous dollars from kent-moore)
I used a pitman arm puller and a 8" piece of 3/8 threaded rod and it worked perfect!
Assembly needs feeler gagues/calipers, bushing installers (sockets) and other stuff. I actually found it easier to use to small screwdrivers than a pair of snapring pliers (quicker for me anyway)
It's not for the faint of heart and everything must be perfectly clean before reassembly. Compressed air is good to check your clutch packs, servos, ect. and to blow out all the passages.
A good book helps too, but to supplement it print all this stuff out:
http://www.transonline.com
http://www.purplesagetradingpost.com...o/700R4p4.html
http://sethirdgen.org/servo.htm
And you can buy alot of parts cheap here:
http://www.hptransparts.com
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 12, 2001 | 05:46 PM
SgtSkip's Avatar
Too cool. I'll probably get one from a junk yard to practice on.
Old Mar 15, 2001 | 10:23 PM
82z's Avatar
82z
They aren't that bad to rebuild. I've reassembled one in about an hour. DO NOT attempt a rebuild without a press/access to, an atsg or equivalnet book, a flat bladed screw driver w/ a notch cut into the side of the blade, lots of light, a teflon seal installing/sizing tool kit(I believe the 700 had some solid teflon seals), a parts cleaner and compressed air. I think you have a good idea in going to the junkyard and getting a core to practice on. To bad they are so expensive. Above all remember "It's just a transmission, don't let it kick your *** ". You will soon learn why they make special tranny tools.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
3.8TransAM
Sep 27, 2015 08:37 PM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
