which T56 to use??
Old Nov 23, 2008 | 09:36 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
which T56 to use??
So here is my problem. I have 2 T56s I know, I know it's a good problem to have. The first is a freshly rebuilt 98 tranny with a full 6 speeds in upgrade kit (billet keys, carbon syncros, steel forks...), also has the stronger 2nd gear since that was shot and necessitated the rebuild. I also have one from a 96 Z28 with 30kish on it. Bone stock but I have the bell housing and slave. Trying to decide which I should use behind the 408 I'm doing for my 89 should be about 520-550hp on motor might do a 100 shot but not for a while. I got a good deal on both and now I'm selling my other car so I was going to use both and now only need one. I know to use the LS1 tranny I need a Mcleod modular bell housing, but to use the LT1 tranny I would have to build it up to hold the abuse of the motor. I don't have a flywheel or anything yet so anybody have thoughts either way on this?
Old Nov 23, 2008 | 10:36 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: which T56 to use??
I have heard that the input shaft will need to be changed out on the ls1 tranny. If you dont have the slave cyl spacer, look out! It's been discontinued and I have been searching everywhere for two weeks and cannot find one anywhere!
Old Nov 24, 2008 | 06:43 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
The LT1 trans. are actally stronger. That spacer comes with the bellhousing, new from GM for 400. I got the whole bellhousing off a 4th gen forum for 75 shipped.;..
Old Nov 24, 2008 | 09:47 AM
WIll36's Avatar
Engine: 355, 408
That may be stock for stock but the LS1 trans has been built to hold 700 whp and tq. Only other mod that could be done to it is a viper mainshaft which would be total overkill given the power level and vehicle weight.
Old Nov 24, 2008 | 11:49 AM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
what are you putting it behind?
Old Nov 30, 2008 | 02:40 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
in his original post he said he was putting it behind a 408. 520-550HP
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
