Are my richmond gears too noisy??
Old Mar 18, 2001 | 10:11 AM
Ant87IROC's Avatar
Car: 87 IROC Z28
Transmission: TH700R4
I had 3.73 richmond gears installed and they are really loud, but thats not the problem, I dont think they were installed right. They are vibrating the car at high speeds and when i come to a stop i get a low pitched, i dont want to say griding noise, but it kinda sounds like that. Will this noise ever go away, or does my pinion gear have to be adjusted. I know richmond gears are notorius for their noise.... but it sounds to me like there is more to it than just the noise... Luckily I have a really loud stereo system to keep me saine! Thanks for any info! Im about to take it to a mechanic to see if it needs some adjusting before they wear in wrong.... Please help me save some cash!!
Ant
87 IROC 305 TPI
Old Mar 18, 2001 | 12:34 PM
82camaro's Avatar
Car: 82 camaro SC
Probably already worn in wrong, if the gears are making the noise. My richmond 3.73's have always been quiet. You put in all new bearings(axle, pinion, carrier) when you had the gears installed? You also check for the proper pattern on the gears and checked backlash?
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
dimented24x7
Sep 6, 2015 03:51 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
