rpms @ various speeds for '91 Rs
Old Nov 25, 2008 | 08:04 PM
camarocate'91's Avatar
Hey, just got a '91 Camaro Rs 3.1 liter V6 and need to determine whether the transmission is functioning normally. Can someone give me an idea of the average rpms that it should run at different speeds? Is 3500 high for 60 mph?
Thanks!
Old Nov 26, 2008 | 07:12 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: rpms @ various speeds for '91 Rs
3500 @ 60 MPH is high. If it is a Auto, you should be at 1000 RPM's @ 40 MPH in OD.
Old Nov 27, 2008 | 10:39 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That's not correct. With the torque converter locked, and the speedometer accurate, my sister's 3.1 Firebird turns 2000 rpm exactly at 65 mph on the original 215/65R15-size tires. So 1000 rpm would be 32.5 mph, but hers won't do less than 35 in OD, with the throttle valve cable set where she likes the way the car behaves.
Old Nov 30, 2008 | 12:58 PM
Thanks. I think the tac might just be wrong; the needle kinda vibrate even when the car's not moving. It's actually reading 3000 @ 60 w/ 70/15s. How much of a difference does that make? It is an auto.
Eric2ndGen
Aug 31, 2015 12:33 AM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
forstral
Aug 19, 2015 03:20 PM
jbd1969
Aug 17, 2015 07:06 PM
