what rearend do i have
Old Nov 27, 2008 | 01:42 PM
ejb38's Avatar
i have a 83 camaro plain jane v6, 26 or 28 spline axles any help thanks
Old Nov 27, 2008 | 01:54 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: what rearend do i have
10 bolt duh lol sorry had to um gears id say 3.08 or 3.23 going buy the chart on the home page for 83 v6 camaro. it could be diffrent if someone changed them out once before. you can do the math if you go lets say 60mph and look at your tach see the rpm then you trans gear ratio like 1:00 if its in third in a 700r4 or d in a th350 tire height. there are some calculators on the wed if you search for some unless someone else can chime in and give a link to a good one. like when i checked my 86 when it was stock i could do 85 cruising at 1900 in od 700r4 came out to 2.73 gears. anyway good luck
Old Nov 29, 2008 | 11:56 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
'83 V6 is 7.5" with 26-spline. It'll hold a mild 350 with a 700R-4.
Old Nov 29, 2008 | 03:14 PM
ejb38's Avatar
thanks
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
