Diffrent Flywheel
Car: 1987 Iroc-Z
Engine: 5.7L SB
Transmission: TKO 500
Axle/Gears: 10 bolt 373's and a Detroit Locker
Diffrent Flywheel
Are there two different flywheels for a roller motor, one piece main seal?
Car: 87 Trans Am
Engine: L98 350 w/carb
Transmission: TH350
Re: Diffrent Flywheel
There are 2 different flywheels for these motors. The 350 will take the 168 tooth flywheel and a 305 will take the 153 tooth flywheel the same goes for flexplates.
Car: 1987 Iroc-Z
Engine: 5.7L SB
Thanks i think i read that somewhere but is there 2 for the 350 motor like a balanced and an unbalanced or something? My transmission guy told me he had a boat that had a nasty vibration in it and he had to change the flywheel to a balanced or or some bs i did not know if he knew what he was talking about so i figured i'd ask here.
~Chris
~Chris
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
There are two flywheels for a 1 piece crank that are 153 tooth, light and heavy. (both external balance)
A 168 won't fit for our cars, doesn't fit inside the bellhousing.
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
