T-5 Fluid
Old Mar 19, 2001 | 06:01 PM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
T-5 Fluid
I know that this is a stupid question but what type of tranny fluid should i put in my T-5?? I am in the process of converting the car from a 700 and this t-5 had no fluid in it when i got it - I just got it rebuild and i have been getting conflicting answers as to what type of fluid it takes - ATF or gear oil?? The tranny is out of an 87 305 TPI car - Thanks - Erik
86 IROC-Z
Silver on dk carmine red deluxe interior
5.0 TPI
2000 New England dragway All Camaro show - Best of show runner up
2000 Heberts Candy mansion cruise night feature car
2000 Shrewsbury Fall brawl - 2nd place
Old Mar 19, 2001 | 06:17 PM
ede's Avatar
ede
i believe only the WC t5s used AFT, starting in 88, but i'm not sure so ther you are another conflicting story.
ICON Motorsports
1st & 3rd
Old Mar 20, 2001 | 08:24 AM
FlashGTA
Guest
Posts: n/a
I had a WC T-5 and it used ATF. Not sure about the standard T-5. I know, thanks for nothing!
Old Mar 20, 2001 | 10:55 AM
MariahFan's Avatar
Car: 86 Z28
Engine: '76 305 0.030 over
My 86 Z takes ATF. I've heard rumour that Borg Warner changed the lubricating material during the life of the T-5. I'm not sure if there is any corresponding hardware changes other than the likely seal changes for lubrication media compatibility. Sorry, I don't think that was much help.
Fluid compatibility is an issue here with the natural vs synthetic hydraulic oils used for helos. Use the synthetic hydraulic fluid in an old helo with natural rubber seals/gaskets and you'll have leaks everywhere!
Old Mar 20, 2001 | 11:51 AM
Chuck Everly's Avatar
GM offers a synthetic manual gear lube and I highly recommend it. If you do not want to spend that much at least get a semi-synthetic ATF.
I put 20K on a T5 with a 383 in front of it. I think the lube helped a lot. As a matter of fact Tremec will not even warrantee a transmission unless you use this GM lube.
Old Mar 20, 2001 | 05:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
82-87 non-world-class T5's use gear oil. 88-92 world class T5's use ATF.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
DARKmj16
Sep 9, 2015 04:07 PM
