install questions 3.42's
Old Mar 20, 2001 | 01:57 AM
pimpintheRS's Avatar
i am installing 3.42's soon i bought my posi already and i need to buy my install kit i am wondering if i need new bearings or not. will my wheel bearings still be good and will my axel bearings still be good i know what is the better thing to do and that is to buy everything new but i have limited money and am wondering if my bearings will work if they are still good.
Shawn
Old Mar 20, 2001 | 12:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Seems kind of dumb to go to all that trouble changing all that stuff and spending hundreds of dollars, then cheap out on the last $20 to make it a perfectly new part, don't you think? Even if they would "work", it's just not a very wise place to try to cut the last corner.
If you buy the full gear install kit (the one that's right at $100) it will have both of the pinion bearings, 2 carrier bearings, the pinion seal, and all the shims for both sets. At that point, all you need is the 2 axle bearings at about $8 each, and the 2 axle seals at about $2.50 each.
Get a 6' piece of water pipe at the hardware store, stick it through, knock the bearing out on the opposite side.
Check the axles carefully where the bearings ride. If they aren't smooth there, with no groove or other signs of wear, you should get other ones.
ICON Motorsports
Old Mar 20, 2001 | 12:52 PM
i was most likely going to buy the kit with everything already but just making sure.all i need to do is buy the kit with the bearings in it. someone was telling me i will need to use a press to take the bearings off the pinion and to put the new ones on is this true?
Shawn
91 RS 5.0 TBI
14x3 open element
160*stat... didnt do anything made my car run a lil cooler
msd coil and taylor wires ...not noticed
with split fire plugs... which suck
removed rear hood seal.. runs much cooler i liked
coming soon 3.42's with slp posi.. my first big mod!!!
Clarion cd player 2 planet audio 6x9's 2 lanzar tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps
Old Mar 20, 2001 | 05:57 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Yes you need a press. You should be able to goto the parts store and have them do it for you. I was told by SLP to change mine when i put my SLP posi in (even though it esentially had new bearings on it)
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
