knocking sound, driveshaft?? HELP!!!!!
Old Nov 30, 2008 | 07:18 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
best way to describe it, is sound like a air chisel under the car, but it goes with driveshaft speed, not engine RPM's so it get faster the faster i go.....one would say DUH your drive shaft is hittin something.....well there is no proof of that, as in i just put my trans back it, and in the process i welded flat steel to outside of the TQ arm, so i repainted it, and there is no scrapes in the paint on it or the driveshaft, drive shaft was given to be out of a 40K mile camaro, it has new joints in it and it has fresh paint with no scrapes in it.
sooooo im lost, any ideas, even dumb ideas, or ideas on how to find where its coming from
Thanks!!!!!!!!!!!
Old Nov 30, 2008 | 08:20 PM
89RS_82Z's Avatar
Re: knocking sound, driveshaft?? HELP!!!!!
bump
Old Dec 1, 2008 | 08:13 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
You may want to have the driveshaft balanced or at least checked before you do anything else. Could have thrown a weight....
Old Dec 1, 2008 | 08:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If so, you should be able to see/feel where the weight was originally.
JamesC
Old Dec 1, 2008 | 11:12 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Noises are hard to tell over the net, but does it make the noise about every 10 feet or so? I've had a pinion gear crack on me and I thought it was the driveshaft at first too. A visual inspection of the driveshaft and pulling the cover on the diff are good places to start. You can also try putting the car on jackstand, remove the driveshaft for a better look and spin the input on the diff to see if it feels like it binds.
Old Dec 1, 2008 | 02:21 PM
89RS_82Z's Avatar
dont look like any weights are missing
LOL if i cracked the pinion then there is an excuse for a LSD
Old Dec 1, 2008 | 05:47 PM
89RS_82Z's Avatar
well i said i wanted a LSD, looks like im getting one, not the way i wantend it and sure cant afford it, as now im going to have to replace the whole rear end
switched out to my old drive shaft just for craps and grins
left out of the house, (going to slow to tell if it was knocking) decided to get on it some and knock knock BANG knock kncok kncok kncok
Attached Thumbnails knocking sound, driveshaft?? HELP!!!!!-dsc08121.jpg   knocking sound, driveshaft?? HELP!!!!!-dsc08120.jpg
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
spartanreaper
Sep 25, 2015 07:22 PM
BLK87Z
Sep 18, 2015 11:29 PM
Ragtop Man
Sep 12, 2015 12:23 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
