Tranny questions
Old Mar 16, 2001 | 07:04 PM
Ron Mullins's Avatar
Tranny questions
I have a 91 Formula with the 700R4. Question is, when I turn corners and start to give it gas to take off, even giving it little gas the tranny down shifts, the rpms jump up and then it immediately shifts back up. Any ideas?
Thanks, Ron.
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, MSD6AL, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Mar 18, 2001 | 08:16 AM
Anybody? I thought of something else it does also. Getting on the freeway sometimes it does the same thing. This is at higher rpms obviously. I can be gettingon the freeway and its like the car doesn't know if it should downshift or not. It does the shifts back up again. It does this a couple times before I just get on it and make it down shift and stay. Then its ok.
91 Formula WS6
Old Mar 18, 2001 | 08:11 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Sounds like the torque converter clutch engaging then disengaging. Might be a couple of things. Computer doing it (did it always do this), leaking tcc seal on end of input spline, bad tc, or something else??? I'm not really sure but some v8 cars I drove had the same prob revving up then down. Like driving on a rollercoaster.
Old Mar 23, 2001 | 07:14 PM
I found the problem. It was low on tranny fluid. Thanks for the input, Ron.
91 Formula WS6
Old Mar 24, 2001 | 02:53 AM
JoelOl75's Avatar
I guess I assume the worst...
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
