Fix T5 crack that leaks?
Old Dec 6, 2008 | 05:08 PM
weinz90's Avatar
Car: 87 IROC, 96 Suburban
Engine: 5.0 TPI, Vortec 5.7
Transmission: T5, Built TCI 4L60E
Axle/Gears: 3.45 posi, 3.73 eaton locker
i have a t5 that has a crack right by the fill plug, its a hairline crack that just seaps but i need it sealed so i can get it to the body shop. i plan on doing a t56 swap in the future. does anyone have any suggestions on a good way to fix the leak for the short term?
thanks
ryan
Old Dec 6, 2008 | 06:52 PM
criz123's Avatar
Re: Fix T5 crack that leaks?
jb weld works if you have it clean and have enough time.
Old Dec 7, 2008 | 12:28 AM
weinz90's Avatar
thanks criz, ill give that a try.
Old Dec 7, 2008 | 10:09 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
If JB doesn't work you can have it TIG welded.
Old Dec 7, 2008 | 10:45 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
LocTite 5900, it's a silicone but for engines, Chrysler used it on their transmissions instead of gaskets. Should run about $12, and would be sold at a tranny shop, would work perfect for a short trip. You would need a caulking gun.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Reid Fleming
Oct 10, 2015 09:56 PM
85 Jimmy
Sep 30, 2015 07:56 AM
mfp189
Sep 27, 2015 09:25 AM
BWilcox
Sep 20, 2015 12:19 PM
