H,im new im doing an engine swap into a third gen the engine i have is a 1974 Pontiac 455 not sure of the hp or torque. I also have a th400 tranny that was with the engine. But i was wonderin if the 83's tranny would hold up to all that torque from the 455? also the th400 is auto and the 83's tranny is manual 5 speed.
aliceempire
close
- Join DateNov 2008
- LocationMilwaukee
- iTrader Positive Feedback100
- iTrader Feedback Score(14)
- Car92 Firebird, 77 Trans Am SE, 86 Z28
- Engine5.7 HSR, T/A 6.6, empty
- TransmissionT-5, TH350, T-5
- Axle/Gears3.08 posi, 3.23 posi, 3.23
- Liked:181 Times in 152 Posts
I'm sure it could hold up for a little while if you have a BOP bellhousing and drive lightly, but drive it hard and it'll break. GM used TH400's for good reason.
On Probation
. If it was my project, I'd plan on a 200-4R trans.ok should i run the 5 speed and then later swap in the th400?
On Probation
You'll need either an adapter kit or a special bellhousing to run the T5. Start with the TH400 and the Hurst torque arm mount.
how much do conversion kits cost?
