3 series Gears and Posi in a 2 series carrier
Can it be done?? Wasn't sure........
Thanks,
John
1991 RS
A couple of mods.....still slow
Team Hells' A-Holes
Member of SDFB
http://www.SDFB.org
Thanks,
John
1991 RS
Team Hells' A-Holes
Member of SDFB
http://www.SDFB.org
Car: Take
Engine: Your
Transmission: Pick
Sure, I put 3.73s on my 2 series posi, you just have to get the 3.73s specificly designed for a 2 series carrier.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
You can use series 3 gears but buy a ring gear spacer, for $45 you get the spacer and new bolts. I ordered mine from scoggin dickey. They work just fine.
Later
John
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Also a cowl for the big hole in the hood.
Shooting for low 12's.
Check out my birds new home.
Later
John
Well, it's more like 3 series gears ON a 2series carrier. All thirdgen 10 bolts have the same "shell", just different insides. You could put a 3 series carrier inside your existing rear and use 3 series gears without a spacer.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
John, are you getting the SLP takeoff posi? Its already 3-series, just get that and the gears and you're set. And you'll also need the right speedo gears for your trans.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Kevin,
Yeah I'm planning on gettin the take off posi and buying a set of 3.42's. I talk to the guys at Pro-Gear here in San Diego and they said it can be done. It's gonna be about $300 for labor though
It's worth it to me though.
CptMidway
1991 RS
Team Hells' A-Holes
Member of SDFB
http://www.SDFB.org
It's worth it to me though.CptMidway
1991 RS
Team Hells' A-Holes
Member of SDFB
http://www.SDFB.org
Car: 4
Engine: 6
Transmission: 5
Somebody else you might want to call is Oceanside Driveline. I've never used any of them though, I do all that sort of thing myself, but they are another place in the area to check anyway.
Like Kevin said, if you get the SLP take-off, it's 3-series. All you need is the standard 3.42 gear. The posi is the carrier.
ICON Motorsports
ICON Motorsports
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
215s, 2series, bonneville, carrier, carrierthirdgen, difference, firebird, gear, gears, housing, posi, put, putting, series, transmission
