rear axles
Old Dec 9, 2008 | 06:22 AM
gcouse7's Avatar
rear axles
I am new here, usually 4th gen stuff. I saw someone selling a 4th gen rear axle for a 3rd gen. Do they fit without sticking out a mile without offset wheels? mounts the same? springs the same size? Thanks for repies.
Old Dec 9, 2008 | 06:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear axles
Welcome to TGO. You'll find that a search here is always a good thing. The fourgens are 2" wider per side. The swap is direct. I'm unsure about the e-brake, however.
JamesC
Old Dec 9, 2008 | 06:37 AM
gcouse7's Avatar
Re: rear axles
Thanks for the speedy reply James. Very glad to hear they interchange because I have a couple to get rid of. As far as the e-brake..... who cares.
Old Dec 9, 2008 | 10:29 AM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: rear axles
If its a LT1 rear end than the e brake will bolt up fine, if its an LS1 rear however, some mods are needed to get it to work. As for sticking out here is my lt1 rear on my 91 RS with 235's on the stock 15 in rims.
Old Dec 9, 2008 | 10:45 AM
JamesC's Avatar
Re: rear axles
Saber's correct: The 89-97 PBR's are nearly identical.
JamesC
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
