Will my POS 10 bolt survive?
Old Mar 27, 2001 | 09:28 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I have a stock 10 bolt in my car with an Auburn Offroad Pro Posi and GM 4.10 gears. I recently put Nitto Drags on my car. I've yet to heat them up good and drop the hammer in fear of grenading my rearend. With my combo (see profile), I figure I'm putting out close to 500 ft-lbs of torque. I am away from home (300 miles) and this is my only mode of transportation at this point. Will it live?
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Mar 27, 2001 | 12:55 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Flip a coin. Heads it lives, tails it dies. Thats about the best we can do.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 27, 2001 | 02:04 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
I'm no drivetrain pro, but after what happened to me i'd say don't tempt fate, if you can help it. I blew up my 3.73 rear end in my '84 (see sig) and I only had a pair of GoodYear Eagle II's out back, P-275-60-R15. Turned out it couldn't take the hit when it shifted from 1st-2nd, that lovely drop in the 700R4. And i've only got a mildly improved L69!! I am planning on going 9-bolt when funds permit.
DR Stevens
Car #1: my ride
1984 TransAm
305HO(L69) 96K & counting
750 cfm Q-Jet/Holley rem.
K&N filter
700R4/Superior shift-kit
and trans cooler
3.42 rear/3.73 blew up!!
underdrive pulleys
Accel HEI Super-Coil
180 stat/hi flow water
pump/Jet fan switch
dual snorkel/'84 ram air
3" exhaust of some sort
partial emissions delete
Car #2: My wife's ride
1991 Firebird/Formula
305TBI(LO3) 99K & smoking
K&N air filter
Hypertech Chip
more engine mods later
"Hey, Uncle Sam!! Where's my f**king tax return??!!"
Old Mar 28, 2001 | 07:28 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You do have the aftermarket posi/31 spline axles.
Most failures I had seen were 26 spliners getting chewed and stock spider gears shattering. That is alot of torque though and nothing is certain.
Maybe a girdle would be a good investment (Not saying it still wont eventually break sometime....... but it will definatly help)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 28, 2001 | 07:49 AM
Mark W. Winning's Avatar
We are running a Alburn posi and GM 3.73's. The car runs 11.70's with a T-350 and 3000 stall. We also run the Nittos. I am afraid of slicks, the the car has many runs on the 7.5.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Mar 28, 2001 | 09:26 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well not to scare you but, I have blowen up my 10 bolt so many times it is pissing me off. I used urban, and gm twice. richmond and now gm again. one axle I had the dealership fix it 3 times me once and a couple of other shops. I think it just gets scared when it hears the tires go up in smoke and decides to brake.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
64Chief
Sep 12, 2015 08:05 AM
92rsvortec350
Sep 10, 2015 10:54 AM
