5 speed manual problems
Old Dec 11, 2008 | 03:14 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
well one day i noticed i was going down the highway getting up to speed fast... coming out of second gear out of a high rpm trying to go into third gear all it do was grind... it didn't go into third at all... but when i got into town and shifted from a low rpm from second gear it went in easily.. but it kinda felt like if was something in the way but it went in. i asked some people in school and a teacher and they said it was the synchronizer. is it true? if so how much does it cost to fix?
Old Dec 12, 2008 | 10:58 PM
Car: 83 Z28 Camaro
Re: 5 speed manual problems
ok so one of my friends told me to put it in third and like rock it or push gas let out and so on and i did like two times or so and it didn't kick it out of gear... and it doesn't kick it out of gear at all... so i don't know what the problem is....
Old Dec 12, 2008 | 11:32 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
sounds like worn synchros or the clutch isn't releasing all the way.
Old Dec 13, 2008 | 04:30 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I had a similar problem when my clutch was not working properly. I would start there. It could be a bent clutch fork or something like that. Does your clutch engage high or low on the pedal?
Old Dec 13, 2008 | 11:53 AM
Car: 83 Z28 Camaro
i believe it engages half way through.... don't really know don't pay much attention. how could it be bent? or what would it have caused it to be bent?
Old Dec 15, 2008 | 01:19 PM
Car: 83 Z28 Camaro
well i noticed that it also does it in 5th but it grinds for a little bit but it goes into gear.... and i also have another question do t5's have problems going into reverse? cause it seems like mine doesn't want to.... when the car is running and doesn't want to go in reverse i just let the clutch out a bit and it goes in??? is that normal?
Old Dec 15, 2008 | 09:12 PM
Car: 83 Z28 Camaro
so i noticed another thing that caught my attention. when i push on my clutch it starts to make a whining noise or some kind of noise... i never noticed it before on my old clutch/transmission and my clutch engages high
Old Dec 17, 2008 | 10:18 PM
Car: 83 Z28 Camaro
Monday im adjusting the clutch. but with manual cars how can you tell if the transmission fluid is going dry?
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
