10 bolt disc rear
Old Mar 31, 2001 | 06:42 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
10 bolt disc rear
well I went to the junk yard today and found an 84 z28 with a 10 bolt disc and 3.23 posi he said he would sell it to me (because I go there so much) for 125.00 is this a deal? I know from my own 10 bolt that they are very weak but, disc in its self makes me wan't it. plus I am redoing mine and would love to have an out of car rebuild with 3.73 gears.
Old Mar 31, 2001 | 07:06 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sounds like a smokin' deal. I wouldn't say they are that weak. There are people running 12's w/ a stock rear.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 31, 2001 | 08:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's still just a 7.5/7.625 diff but just to get the housing with disk brakes is worth it. You can always get a 28 spline carrier from an 88 to present f-body or even an s-10 from the same years and install aftermarket 28 spline axles from www.tomsdifferencials.com
Don't forget if you're swapping from drum to disk you should also change the master cylinder and pressure differencial switch (proportioning valve). Grab those also but you'll have problems with the brake lines. The 84 will have standard lines and fittings and your 88 will have metric.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Apr 1, 2001 | 08:52 AM
Biochem's Avatar
Car: 2002 SOM z28
Ummm... make sure it has 10 bolts around the rear! I won't tell you how many bolts my disk brake/posi rear from a 84 that I bought from a junkyard actually has... (hint: look at my sig.)
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
[This message has been edited by Biochem (edited April 01, 2001).]
Old Apr 1, 2001 | 11:24 AM
Engine: ls1, LB9
I was looking for a 9 bolt disc rear and was having no luck when I decided thet maybe this old 84 might have aluminum drums so I looked and saw disc and thought this is odd and looked under the car and counted 10 bolts. I thought that I made a mistake and crawled under it and had to count it 3 more times then I checked the glove box to see that it had 3.23 (GU5) and posi (G80) the rotors were very rusty but, no pitting.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
