B&M Deep Tranny Pan. Good idea??
Old Mar 30, 2001 | 12:50 PM
CAMARORS1991's Avatar
Does anyone with a stock height thirdgen have the B&M deep pan installed on their tranny?? If so, what kind of clearance do you have and do you constantly have to avoid speed bumps?? I bought one but have not installed it yet. Guess I shouldve asked these questions earlier.
Old Mar 30, 2001 | 02:18 PM
Desert86Roc's Avatar
I orginally installed my Hughes unit with a deep pan. I drove it for a month like that and there was not enough clearance. It was actually lower than the lowest suspension part on the car. So instead of continually wondering if I was going to hit it, I traded it for a standard depth pan. Save yourself some time and go with a standard pan.
Mike Metzler (Desert86Roc)[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For 86 IROC 305 TPI (406 build in progress) Page
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, headers, no NOS)
Old Mar 30, 2001 | 07:27 PM
FlashGTA
Guest
Posts: n/a
I put a Derale Pan on with the cooling tubes in it. It cut down clearance significantly and was the lowest part of the car. I was very careful with it and didn't have any problems. My wife however drives my car like she hates it and crushed it. I would go with a stock depth pan if I were you, I am (again!).
Old Mar 30, 2001 | 07:46 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
do you think that the stock deep pan from an s10 would work? then you would even have an easy to find filter #, If I remember they are only 1/4-1-2" deeper than stock 3rd gens
Old Apr 1, 2001 | 01:31 AM
FlashGTA
Guest
Posts: n/a
Is it worth the hassle for 1/4 to 1/2 inch?
Old Apr 1, 2001 | 11:49 AM
Engine: ls1, LB9
It is all up to the user if it is worth it. It must help if gm decided to use it right? and it really is not that much of a hassle to get a pan and filter for a 98 s-10.
camaro11j
Sep 19, 2018 08:49 AM
kah992
Aug 19, 2015 02:55 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
