Question on a T-5
Old Dec 16, 2008 | 11:18 AM
AngryChimp's Avatar
Car: 91 Camaro RS
Engine: 305 bored 40 over, Built For Auto X
Transmission: 700r4, swapping to a T-5
Question on a T-5
Hi ya'll, ok I found a T-5 5spd, But it came out of a V6. I was told that it would work on a V8. I know I have to get the bellhousing for V8. My question is on the t-5 that came out of a V6 has a input shaft spline of 14 and all the clutchs' I can find for a V8 are 10 and 26. And GM doesn't make that input shaft anymore. So will a performance clutch and flywheel for a V6 be able to handle the V8??
Thanx guys, Travis
Old Dec 16, 2008 | 12:16 PM
Shagwell's Avatar
Car: projects.......
Re: Question on a T-5
Lots of info about this available from a search.
Basically, the trans won't bolt to the V8 bellhousing, and you'll need to run a v6/14 spline clutch disc with a V8 pressure plate. - The correct pieces to use are listed in many of the threads about this, again, hit up the search key for tons of info.
Old Dec 16, 2008 | 02:13 PM
AngryChimp's Avatar
Car: 91 Camaro RS
So the V6 and V8 clutchs are the same size? Cool thanx man you been a lot of help.
Old Dec 16, 2008 | 02:48 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
I have done this swap it works but the trans won't live long behind a good V-8
Weird gear ratio too ...use clutch disk for a 87 S-10 blazer 4x4 --- standard V-8 pressure plate
Old Dec 16, 2008 | 03:09 PM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Not to hi jack the post but I did the same thing purchaced a completly rebuilt T5 from a 97-02 camaro with a 26 spline input shaft from the 88-92 camaros which can still be purchased today. The ratios in mine are 2.75-1.94-1.34-1.0-0.74. From what I am reading it WILL NOT bolt up to the third gen bell. What are my options?
Old Dec 16, 2008 | 05:51 PM
big gear head's Avatar
My brother tried to put a T5 from a 2.8 V6 behind a 4.3 V6 by using a V8 bellhousing. The input shaft was too long and the bearing retainer was also too long. The case bolted up just fine, but the shaft and bearing retainer required some work. He used a clutch disc from an Astro van.
midge54
Sep 2, 2015 06:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Cacike
Aug 27, 2015 05:10 PM
redmaroz
Aug 16, 2015 11:40 PM
