Transmission pump replacement???
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
Is there anything speacial that i need to know about replacing my trans pump. i know the basic things that i have to do to replace it. But i dont want to screw it up so any help is appreciated.
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: Transmission pump replacement???
pull the pan. pull the tcc solenoid. pull the trans filter. pull the tube for aux valve body that fits in the pump. pull the bolts for the pump. pull the pump with a pump puller (I use a pry bar between the pump and reverse input drum with success but carefully if no pump puller is available.) Why not rebuild yours? They rarely need more than a bushing and seals, just unbolt it once you get it out and go from there.
