cracked pinion
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
cracked pinion
well I finally went out side and tore down my 10 bolt to find what pinion bearing went bad. and what to my surprise the bearings were fine so while inspecting the teeth for abnormal wear I noticed a crack in on of the valleys on the pinion so further cleaning I see that the pinion has this crack going from the valley to the center of the pinion(the shaft)on about 4 teeth. what happened? the bearing look great and the teeth were riding perfect. I have a fairly built 350 but, does it have that much torque? I noticed I had a problem because every time it would heat up I could hear a noise like a spun bearing but, I guess It was just the cracks allowing the pinion to change is shape slightly and ride different.
Car: Take
Engine: Your
Transmission: Pick
If they are new gears, they may have not been "broken in" properly. When new gears "break in", they wear, and create heat. If you don't do it in stages, you can overheat them, and they will loose there "temper".
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Engine: ls1, LB9
they are about 1-2 years old had the dealership rebuild my rearend while I was in school. they installed every thing new. all but one axle.
Transmission: 4L80E/4L80E
It was probably a bad gear. Overheating would tend to accelerate wear on the teeth surfaces, not cause cracks at the tooth root. Although gears are made from pretty hard steel, overheating would tend to deteriorate the case hardening. It's not uncommon for improper through-heat treating to cause cracks, though.
I'd say you have a warranty claim (latent defect).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
