Can a T-5 handle my engine??
Old Mar 27, 2001 | 05:17 PM
chicksL69's Avatar
Hi, I have a pretty strong engine (nothing spectacular, but stronger than stock) about 340-350hp. It's explained in my signature. Anyways, my car is an orig automatic, and I want a manual BAD. t56's are awesome but too much for me to spend. is there ANY other tranny that is manual, will fit in a 84 camaro, and can handle my engine?? Thank you!!
Old Mar 27, 2001 | 05:18 PM
chicksL69's Avatar
sorry, here's my signature.
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
461 double hump heads
2.02/1.60 valves
edelbrock perf RPM intake
edelbrock 600 cfm carb
th-350 tranny
B&M stage 2 Transpak
aluminum roller rockers
489 lift cam
7 quart oil pan
Keith Black pistons
screw in studs/guideplate
Old Mar 27, 2001 | 05:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A Tremec will handle it too, but its just as expensive. An 88-92 World Class T5 will handle the power, but if you race, or power shift it, you will shorten its life tremendously. First and third gears are the problem, and there isnt much you can do to beef it up.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 27, 2001 | 09:21 PM
84TransAm's Avatar
Didn't some 82-84 F bodies come with 4 speeds? Maybe look into that.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Old Apr 4, 2001 | 08:48 PM
MikeS's Avatar
And then there's the T56 six speed swap...
Old Apr 4, 2001 | 09:18 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
the T-5 will be alright provided you do a quality re-build on it, and your extremely nice to it. as said before, powershifting, brakestands, and hard racing will shorten its life a whole lot. Get the WC T-5 too, it's a little bit stronger that the BW, which is what i have behind my 350. Ive had it for over a year now, and no problems so far. (it never been rebuilt either )
My 1986 Z28 and more!!
85 IROC w/ 1364 miles!
R.I.P Dale Earnhardt
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
