Torque Arm Removal Question
Old Apr 5, 2001 | 08:38 AM
fast89's Avatar
IS the torque arm under pressure when the car is not running? I am starting my trans removal and I need to remove the torque arm bolts but I am not sure if it is under any pressure. Also, are there special tolls needed to install a corvette servo or can basic tools be used. As you can see I am learning as I go with this removal. :-)
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires
Old Apr 5, 2001 | 08:43 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
The torque arm is under a certain amount of pressure if the rear-end is hanging when you jack the car up. I would put the jackstands under the axle tubes. This will eliminate most of the pressure. Then put a piece of wood between the floorpan and the torque arm just to be safe and remove the front mount first. You should then be able to move the torque arm by hand and position it so that there is no pressure. Then remove the two rear bolts. Good luck.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Apr 5, 2001 | 10:46 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
your coil springs are what is keeping pressure on the torque arm.if you remove the bolts that are holding the torqe arm to the tranny with out releiving that pressure the torque arm WILL pivit upwards very violently and break any thing in it's way(speedo gear).so tp releive that pressure remove the coil springs.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Apr 5, 2001 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I do mine like Frank says. Jack the car up, support it by the frame, let the rear end all the way down, jack it back up an inch or 2, put a second pair of jack stands under the axle tubes up high enough to support the rear before it reaches the end of the shocks' travel. Then there is very little force on the TA, and you can move it around fairly easily.
ICON Motorsports
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
