TV cable questions
Old Dec 23, 2008 | 08:45 AM
mark87Z28's Avatar
TV cable questions
With the trans installed in the car I can't quite get to the tv cable mount at the trans. It looks like I need to lower the trans to get to the cable. I can place the car on stands and a jack under the pan and remove the trans cross memeber. Will this give the clearnace needed?
Old Dec 25, 2008 | 11:02 AM
blp226's Avatar
Re: TV cable questions
I had the same problem with my 84. I did what you suggested. It's still a bit tight though. I took the trans pan off and it made the difference!
Lower the trans like you said in your post, drop the pan and it will be a piece of cake.
Old Dec 29, 2008 | 02:06 PM
mark87Z28's Avatar
Did you remove the driveshaft at the differential, the distributor cap, and air cleaner?
Thanks for the tip on removing the pan.
Did the new cable help with any issues?
Old Dec 29, 2008 | 03:37 PM
CamaroLover09's Avatar
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
I popped the distributor cap off and then put the jack back on the bracket that attaches to the tranny back by the crossmember. Then I removed the crossmember and lowered the transmission until I started to hear wire looms start to crinkles between the heads and the firewall. It was still tight as hell but we managed to get the boot of the tv cable in place after about 2 and a half hours of dicking with it. I didn't have a new gasket or a bucket to catch the fluid so we didn't pull the pan.
Btw, the new tv cable didn't help a damn thing for me. My tranny won't shift out of first until about 4500 rpm and it makes the whole car lurch. The 2-3 shift is about 500 rpm higher than normal but it doesn't try to snap my neck like 1-2. I'm also not getting OD and torque converter lock up until I run it up to about 50 mph and let off the accelerator.
I'm going to replace the governor and flush the tranny oil. If that doesn't help, it's time for an overhaul.
Last edited by CamaroLover09; Dec 29, 2008 at 03:42 PM. Reason: Automerged Doublepost
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
