Bellhousing & Flywheel?
I am swapping out my tired '89 305 (one piece rear main seal) for a newly rebuilt '76 350 (two piece rear main seal) and was wondering if I could still use my stock bellhousing and flywheel from '89?
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
The bellhousing will work on all Chevy smallblocks (up to, but not including LS1/LS6), 4.3 V6's, and bigblocks. However, the flywheel will not work since your '89 uses a 1-piece rear main and you have a 2-piece. Just get an old style 350 flywheel.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Car: 4
Engine: 6
Transmission: 5
Frank is right about the bell housing. However, most 350 flywheels won't work for your swap, because they're 14", and a 14" won't go in the only bellhousing that fit these cars, which only accommodates the 12¾" one. The flywheel to get is the one for a 83-84 HO 5-speed car. The one from the LG4 in those years will also work, but the HO one is the lighter one, and therefore better in this application.
ICON Motorsports
ICON Motorsports
monte87cortez
Sep 26, 2015 08:10 PM
