any tips on carrier removal..9 bolt
Old Dec 26, 2008 | 04:13 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Ok i got the bearing caps off and the axles out but the carrier is really wedged in there. Any tips on how to get it out? I was using a breaker bar as a pry bar and trying to pop it out that way but no dice.
Old Dec 26, 2008 | 04:18 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: any tips on carrier removal..9 bolt
Put the car in Neutral and make sure there isn't a stress. Then put it back in park and use the breaker bar as a wedge again. That is what I did.
Old Dec 26, 2008 | 04:19 PM
subroc's Avatar
Engine: 355 TPI
Might have wanted to add that the rearend is out of the car.
Old Dec 26, 2008 | 04:23 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Hmmm. I had to wedge something in and use a hammer to tap it out. Try and do some hard quick taps, but make sure you don't hit the gears, just the carrier.
Old Dec 26, 2008 | 04:30 PM
subroc's Avatar
Engine: 355 TPI
hmm thanks ill try that
Old Dec 26, 2008 | 05:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What are you doing to it? If you are rebuilding it, if you have any questions, feel free to ask me. I rebuilt mine and I am about to rebuild another one. I am quite familiar with these.
Old Dec 26, 2008 | 05:45 PM
subroc's Avatar
Engine: 355 TPI
I might actually. I have step by step instructions on how to shim it but it seems i need to bring the cones to a machine shop and have them turned down on a lath. They are a bit worn at the end but the case itself has not been cut..yet. I caught it just in time i think. By the way if you couldnt tell from what i just wrote...i got it out and apart. Thanks for the tip
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
