Will a transgo shift kit cure this
Old Apr 8, 2001 | 09:05 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
AT full thottle my 700r4 willnot make the second to third shift until I let up on the thottle some I have four other Iroc owners with the same problem 85-89. THANKS FOR ALL RESPONSES MR. KIDD
Old Apr 9, 2001 | 04:18 AM
Pro Built Automatics's Avatar
There are a couple of things that prevent this (2-3 shift from happening) especially with some miles. If you have this problem & everything is still stock, then try the Trans-Go Perf Shift kit along with the large boost valves & Corvette servo. In most cases this will solve the problem, this is assuming that the sealing rings & seals are in good order, and the 3-4 clutch pack is not glazed & that there is not too much clearence in the 3-4 clutch pack. The Trans-Go kit will raise line pressure & triple the amount of oil going to the 3-4 clutches. This in most cases solves the problem. If there are any questions you can call if you desire 800 7763288 Mon-Sat 11-7 PST, & I will be glad too help!
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
