T56 fluid seepage
Old Dec 30, 2008 | 09:48 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
T56 fluid seepage
I was under my car right before winter changing the oil and I noticed a very little amount of transmission fluid seepage where the T56 connects to the bellhousing. I'm not very worried about it seeing as in never really dripped onto the concrete yet. What do you guys think this is? The trans is used out of a 97 trans am. Motor specs are in sig. I didn't use any sealer on the drain plug or the fill plug. It was dark and all I had was my trouble light so I didn't bother to check...
Old Dec 30, 2008 | 11:41 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: T56 fluid seepage
chances are its the rear main seal...or the input shaft seal, which ive never really seen go bad, but anything is possible i guess.
Old Dec 30, 2008 | 07:52 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Trans fluid; input shaft seal
Engine Oil; rear main seal leak.
There aren't any other liquids near there.
Old Dec 30, 2008 | 09:11 PM
ssean92's Avatar
Car: sold
I changed mine for the same reason, not to hard to do at all
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
