700R4 - 1991 Z28
Old Dec 31, 2008 | 02:22 PM
KSK60's Avatar
700R4 - 1991 Z28
Sometimes when the accelerator is floored the transmission slips out of gear & the RPM's go through the roof. Any suggestions for a fix? 350 TPI engine.
Old Dec 31, 2008 | 02:26 PM
Uncle Paul's Avatar
Re: 700R4 - 1991 Z28
Is this from a roll? At highway speeds? When downshifting? Upshifting?
The short answer is a burnt up clutch pack. But without hearing more of the details, I wouldn't be able to say 100%.
Old Jan 1, 2009 | 06:33 AM
KSK60's Avatar
Downshifting is fine. Off the line shifting is Ok until shifting into drive & OD. At highway speeds, it instantly comes out of gear under hard acceleration. Thanks
Old Jan 1, 2009 | 09:02 AM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
tranny could be slipping or your low on tranny fluid also check your kick down cable from the motor to the tranny
Old Jan 7, 2009 | 04:57 AM
Pat Hall's Avatar
It may not even be slipping. Our cars are setup to kick down into 3rd gear when you push the accelerator down more than 2/3 of the way. It doesn't matter if you're going over 100 mph, if you floor it, it'll kick out of OD and into 3rd gear, and believe me, at that speed the rpm's will hit the roof in 3rd! Ask me how I know. The Corvettes and cop cars are set up to stay in OD with the throttle floored, but not the f-bodies.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
Jlanz55
Sep 8, 2015 11:28 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
